Attribute Table widget > Customize > add separate toggle for field formatting
502
06-24-2025 11:08 AM
Status: Open
Labels (2)
AnitaB
The Attribute Table widget allows to "customize".   Not really.
I choose "use layer settings", with layer-defined formatting.  Great, Iooks good.  But I don't want the layer-defined attribute order.  I'd also like to hide a field, maybe two.  Not possible.
I choose "customize".  I can now reorder fields; I can turn off a field.  Perfect, I'm nearly there.  But it also turns off the layer-defined attribute formatting.  Now I have undesired thousand separators in my integers and hours in my dates.  I can't do anything to those no longer formatted fields, so turning on "customize" doesn't get me a win.  Nor can I turn them back on, yet still keep my reordered or hidden field.  Nuts.
"Customize" would imply that I have the option to modify table components separately.
 Preferred: allow me to independently choose to turn these options on/off for a CUSTOM-designed experience.  The first two we can already do as separate actions when in "customize" mode.  How about adding the flexibility to have the third as a separate option, too?
  • Reorder fields
  • Hide fields
  • toggle layer-defined formatting on/off
My original posting to Esri Community with a couple of screen shots, is here:
Re: Attribute Table widget > configure fields > cu... - Esri Community
