ArcGIS Experience Builder Text Widget - Include Table option
1517
12-13-2024 10:20 AM
Status: Open
Labels (2)
LJackson29
In the Experience Builder Text widget, allow user to create a table to display information. This would not be connected to a data source, but just an additional text option. Similar to the table option in this comment editor (see image below). Currently, if I want to display some information in a table, I have to create the table outside of EB and add it as an image.
Thanks!
4 Comments
JeffreyThompson2
You could build your own table with a Grid Widget.
LJackson29
@JeffreyThompson2 Thanks for the suggestion that could work in some situations, but far from ideal having to have a grid widget and then a text widget for each cell when you have a table such as this:
JeffreyThompson2
Add a Grid. Put a Text Widget in it. Click on the Text Widget and use the Duplicate Button. You should be able to build a Table fairly quickly.
LJackson29
I am bring this up again - while the grid option is a work around, the amount of time it takes me to create a table using the grid widget, adding text to each cell, and getting everything aligned is a major waste of time. Please just add a table option or HTML option where you can build a table to the the text widget 😊. This is an ongoing issue for me.
