I have a table widget that displays numerical data. With longer numbers, a thousandth separator is added by default to the number. Example:
In some instances, having a thousandth separator does not make sense and should be removed. Experience Builder does not provide a solution to that (one solution was offered here Removing 1000th separators from table widget which did not work for my case).
I suggest adding a toggle button to al Experience Builder widgets that would allow users to turn on/off the option to have a thousandth separator.
I can imagine a toggle button just like in Map Viewer under the Fields toolbar:
Hi @doronwen, thanks for your idea. Our colleagues from the Maps SDK team are working on the feature table widget honoring number/date format from the web maps, and custom layer formatting. Once it's supported from the Maps SDK end, the Experience Builder team will be able to support it. It's on track, and I'll keep you updated on this.
Hey @doronwen,
I also opened an Idea about thousand seperators: https://community.esri.com/t5/arcgis-survey123-ideas/cofigure-thousand-separators/idi-p/1303770
In this Idea I suggested that throughout the entire ESRI World you have a toggle button where you can activate and deactivate the thousand separator.
I really cannot understand why there seems to be no standard for stuff like this througout the ESRI software. To me it seems like there are so many development teams and every single one of them is doing their own thing an in the end everythin is duck taped together.
There are so many posts about thousand seperators alone. If there would be a good ESRI Standard througout all their software, people would save a lot of energy and could do cool stuff.
But that is just an opinion of a customer...
