Experience Builder has so much potential, but we can't implement it until a batch editor capability is added. It is so convenient to be able to select multiple features and edit their attributes simultaneously rather than selecting one-by-one.
In Web AppBuilder, the Batch Attribute Editing widget only supported being connected to editable feature layers from your map and did not support editing records from standalone layers and table layers.
Once implemented, support for batch editing in the "Attribute only" mode is an enhancement in Experience Builder that will allow you to also batch edit from feature layers and also table layer that are added to your app but not necessarily also in your map.
@AlixVezina thanks for the response. Can you clarify what you mean by this: "Allow you to also batch edit from feature layers and also table layer that are added to your app but not necessarily also in your map."
Will table layers and feature layers in maps not have batch attribute editing?
Also cross-referencing your response in the new idea listed above.
When configuring the Edit widget, you will find two modes are available:
Interact with a Map widget - the Edit widget will only read the feature layers from the maps in a Map widget for editing. This is similar to what was available in the Batch Attribute Editor widget in Web AppBuilder, where a map was always required in your app for the widgets to work. This newly introduced batch editing option in the Edit widget allows editing the feature's attributes and also their geometries. This was the main workflow the Experience Builder team was focused on supporting for batch editing in this initial release of the functionality.
Attribute only - you can connect the Edit widget to any editable layers in your app, may they be in a map or not. This option only allows you to edit the attributes for features (in a feature layer) and records (in a table layer) - it does not allow you to edit geometries in the map. Technically, with this option, you could build an app with only a Table and the Edit widget and no map at all (example below). This is a new type of workflow that we did not previously support in Web AppBuilder. The team will add support for batch editing in this case too, in a future release, so you'll get the new ability to also batch edit records from a table layer.
@StuartMoore found this issue with the new Batch Attribute Editing functionality and saving values returned in calculated fields - posting for cross reference. Nearly there but not quite!
@AlixVezina - I think the issue is that Interact with a Map mode only allows turning on/off Capabilities for each layer (Add/Delete/update), whereas Attribute only mode allows turning on/off Capabilities AND it allows Configure fields (to show/editable).
Could Esri add "Configure fields" options to the Interact with a Map mode?
Since it is possible to create different Forms for a same layer in different maps, I suggest creating a map tailored to your Batch editing workflows and customizing a Form for batch editing.
