Add a 'Cancel' button to the Edit Widget
1744
12-31-2024 09:32 AM
Status: Open
Labels (2)
doronwen
When a layer is setup to only be edited for 'Attributes', the Edit widget does not have an option to 'Cancel' edits. The only option available is 'Update'.
As far as I know, if a user wants to cancel their edits they need to close the window/tab of the browser and then the edits are not saved.
Tags (1)
4 Comments
D_Atkins
While not nearly as intuitive as a Cancel button, the "Back button" (an Arrow, really) will prompt a user with the option to "Continue editing" or "Discard edits".
A cancel button would likely be better, but the back button is probably a step ahead of closing out of the Experience completely.
doronwen
@D_Atkins I agree with you, but if Esri provides more than one option to deal with this situation that would be ideal.
HollyTorpey_LSA
I would love to see a cancel button on the Edit widget whether editing attributes only or geometry and attributes. Here's a thread with further discussion: Solved: Re: Edit Widget - Cancel Edits - Esri Community.
Laura
by MVP Regular Contributor
Second what @D_Atkins said. You have to use the arrow but I've had to point that out to pretty much every user and seems it would be easier for them if there was a cancel option.
No need to close the whole tab - that would be a hectic workflow.
