Ability to change the default units in measure widget
1878
10-10-2023 12:41 PM
Status: Open
ScottKiley
The measure widget inside the experience builder's map widget doesn't allow any configuration. It would be great if we're able to set the default units of that measure widget to the any of the options available within the widget.
Tags (1)
2 Comments
ChrisUnderwood
Hello @ScottKiley  , there is a similar Idea already posted here. You might like to add your Kudos to that, to further raise it's profile.
https://community.esri.com/t5/arcgis-experience-builder-ideas/exb-make-the-built-in-widgets-to-the-m...
 The comments also point to a custom tool that apparently offers the functionality you are interested in.
AmyRoust
I just logged in to suggest this! Definitely need this option.
