Use the filtered value as a default field value
4143
6
12-29-2023 01:26 PM
Labels (2)
AlixVezina
Topic – Migrating from Web AppBuilder to Experience Builder
The Smart Editor widget in Web AppBuilder provides a variety of configuration options to save time for editors by enforcing data integrity with field conditions and automating the calculation of field values.
Much of this functionality is now available through Smart Forms. To learn more, check out this blog: From the Smart Editor to Smart Forms
The functionality we describe in this blog belongs to very specific workflows and we thought it may deserve a dedicated post.
In Web AppBuilder
In Web AppBuilder, you can set up an interaction between the Group Filter widget and the Smart Editor widget to use the filtered value as a default value for attribute fields when you create new features.
As illustrated in the example app below, when a user filters features from the Event map to view a specific event, the event name value will be automatically populated into the Event identifier field for any new features they create for that event.
This option can be enabled in the Smart Editor widget General Settings, along with setting up Preset Attribute Actions and proper filters in the Group Filter widget.
In Experience Builder
To recreate this functionality in Experience Builder, you’ll need to configure Forms in Map Viewer for your editable layers. Add a calculated expression to the form using Arcade to calculate and populate data automatically.
Follow these steps with this sample map to view an example:
1. In Map Viewer, apply a new Filter Expression on the Filtered Layer for one of the values (e.g., value 5 below).
2. Then, use the Edit tool to add a new feature for the Editable Layer.
Notice how the value from the remaining feature (value 5, in the example above) is written into the field automatically.
How was this achieved? Let’s take a look at the Form:
3. Open the Forms configuration for the Editable Layer.
4. For the Value from filter field you'll see a Calculated expression is set.
5. Click the gear and Edit Arcade to view and modify the expression. 
6. For an expression using your own layers in your own web map, you'll need to replace the elements underlined in red and blue below.
  • Red: the layer and field the filtered value is coming from.
  • Blue: the target field for the filtered value in the target layer (this is the one for which you are configuring the Form).
Here's the code snippet:
function getValue() {
  // Define which layer and field to grab the value from
  var queryLayer = FeatureSetByName($map, "Filtered Layer", ["Value_to_filter"], false);
  // Return the value from the first feature returned when querying that layer
  var firstFeature = First(queryLayer);
  if (IsEmpty(firstFeature))
    return null; // Layer is empty.
  return firstFeature["Value_to_filter"];
// Only perform this calculation when a new feature is created
if ($editContext.editType == "INSERT" && $feature.Value_from_filter == null) {
  return getValue()
} else {
  // When the feature is updated, return the existing value in this field
  // and do not calculate a new value
  return $feature.Value_from_filter
Note: this will only work as expected if a filter is applied. If no filter is applied, an unexpected value may be populated.
Once you've set the Calculated expression in the Map Viewer using the Forms, this logic will also work when using this web map in Experience Builder with the Filter and Edit widgets.
Check out this application example:
We must all thank @ChrisDelaney for coming up with this approach!
6 Comments
WetherbeeDorshow
Basically, I have a layer with multiple fields that store default values for corresponding fields in a set of new editable features. If I choose the right filtered layer, I want the new features created to take the calculated values for all of the relevant fields.
Would it be possible to use the same expression for each calculated field, changing the Field Name values from the filtered layer?
AlixVezina
Hi @WetherbeeDorshow !
Apologies, I am not sure if I understand the question. Please would you be able to explain into more details and perhaps illustrate how your data is setup and how you'd like it to work? Thank you!
Beany
Hi @AlixVezina, thanks for such a great post.
I have followed the steps above and I can replicate your results in Map Viewer. However when I try to replicate the result in an Experience Builder application using the Filter and Widget tools I have no luck!
The target field in the editable layer ignores the value in the filter widget and will only return the first value from the filtered layer. It seems that the edit widget is not "seeing" the filtered layer properly.
My target layer is a hosted feature service and my filtered layer is a hosted table.
I can see in the screenshot that the filter is toggled off but I promise that I tested it with the filter on....
Value in the field of the edit feature not the same as the filter choiceValue in the field of the edit feature not the same as the filter choice
I would love some advice as this is exactly the functionality that I need!
Thanks so much for your help. On Enterprise 11.3.
AlixVezina
Hi @Beany ! Maybe we can take a closer look at your setup, to see where the catch may be. Are you able to share you project with me? Feel free to send me an email directly with the details so I can review your map and app, or we can setup a screenshare when is convenient > [email protected]
Beany
Hi @AlixVezina, thanks for your offer! I have sent you an email
AlixVezina
@Beany 's issue was identified as a bug in Enterprise 11.3 where the filtered value in Table layers is not being recognized in this use case. This bug was resolved in the November 2024 update of Experience Builder and should not occur in later builds of Experience Builder, also starting at Enterprise 11.5.
Contributors
About the Author
Alix is a senior product engineer on Esri's ArcGIS Solutions Web Development team, where she delivers innovative web mapping tools for various industries. She's passionate about customer success and combines her knowledge and experience to help solve problems and empower others to develop impactful applications that provide essential functionality.
