Info Summary in Experience Builder (Update: Implemented)
17021
38
11-03-2022 07:23 AM
AlixVezina
3 38 17K
Updated: Implemented, see Recreating Web Appbuilder Info Summary widget workflows in Experience Builder (esri.com)
In ArcGIS Web AppBuilder (WAB), the Info Summary widget allows you to quickly view a count and a list of features for each layer specified.
Are you using this widget? Here's an opportunity to tell us what you need in the new generation of app builders!
Please add a comment to this blog and answer the questions below. You can also contact me directly at [email protected].
  1. What functionality from the WAB Info Summary widget do you need in Experience Builder?
  2. Is there any new functionality you would like to see in this widget?
  3. Tell us about an application you've created in Web AppBuilder using the Info Summary widget. Share a link, screenshots, or recording if possible. Describe the application and explain how it's being used, and by whom.
  4. Tell us about you: your role, your industry, how you apply GIS?
38 Comments
wcozzens
The Info Summary widget in WAB is probably the most used widget in all of our web apps and dashboard themes. It's a quick, intuitive way for users to quickly identify and navigate to key points on a map. The existing features of the widget work well for our needs. In Experience Builder it would be ideal if this widget could also interact with other widgets. The Info Summary and Add Data widgets are the two key things currently missing from EB, and reason enough NOT to use EB until these have been added. Please feel free to contact me directly if you would like to see some live examples.
ChrisRoberts2
The Info Summary widget and lack thereof in EB is a showstopper for us to move a number of web apps over.
For example:
Code Amendment Map Viewer (geohub.sa.gov.au)
ReedWhittington
Occasional Explorer
It seems to me after brief exposure to ExB that the table widget and query widget could be tied together so that the query result could be fed to the table.   Or have the query widget result displayed as a read only table.
KevinMayall
I want to display a count and list of features (businesses) for each value in a category field (type of business).  The WAB Info Summary widget is useful because it shows the counts for each category alongside the the map symbol for each category.  The use of the map symbols helps to relate the widget to the map.
I don't use the Display Logo Image, Show All Features or the clustering options.
I also need for an EB widget to expand the summary rows to show individual record names.
We use this for a local business directory.  I am a GIS consultant acting for a local business development agency.
AlixVezina
Info Summary functionality can now be set up in Experience Builder using the Near Me widget available in ArcGIS Online since June 2023. See What’s New in ArcGIS Experience Builder (June 2023) (esri.com)
Here's the blog with the configuration steps:
Example:
Laura
by MVP Regular Contributor
I think a good example is the crime solution. There is an info summary widget and there I was able to break down the crimes by type of crime showing the counts but also the corresponding symbology for that type. In the above example there is no symbology. I think that EXB is making the simple things too complicated. I would like to get what WAB had, but get there quicker and easier than I currently can. EXB still does not have what I would prefer. It's hard to keep up with the game always changing when the good changes are implemented so late. When it comes down to what the users really want to see then WAB is the way to go.
AlixVezina
@Laura Thank you for the feedback!
We'll take note of your need to "break down the crimes by type of crime showing the counts but also the corresponding symbology for that type".
Do you have any other specific suggestions on how we can improve the Info Summary workflow in Experience Builder?
ChrisRoberts2
I agree with @Laura. Just a simply Symbol, Type and count meets the needs I have in order to migrate some of my simple apps  from WAB to Experience Builder
JarrettLivesey1
Hi Alix, and thank you for asking for input about how best to migrate the 'Info Summary' app over to Experience Builder.    I agree with @Laura; having the app tally, but also individually break down by category, is what I would like to see in the Experience builder version of the Widget.  I currently use 'Info Summary' in a Damage assessment App that updates real time as team members are collecting information in the field.  You can view the at THIS LINK
Alix, feel free to reach out if you have any questions about any of this.
Jarrett
AlixVezina
@JarrettLivesey1 Here's an example of how you could recreate something similar using the Near Me widget in Experience Builder, using the web map that you shared: Damage Assessment Dashboard - example only (arcgis.com)
Would something like this work for you? Is there anything missing?
JarrettLivesey1
Hello and good morning @AlixVezina, thanks for putting this together so fast !!
Two things; are you able to add the icon for the different 'extent of damage' to list on the left side of the screen ??
Also in the list can you add other text where the dollar value currently is ??  Something like "value before damage" = $ 149000, etc.
Lastly, how did you replicate the 'Info Summary' widget in Experience builder ??
Thanks for your help it is very much appreciated 🙂
Jarrett
AlixVezina
@JarrettLivesey1
Are you able to add the icon for the different 'extent of damage' to list on the left side of the screen ??
No, right now we don't support adding the symbols as icons. But we'll consider it.
Not at this time, there's only one display field that can be defined. But we'll consider it.
How did you replicate the 'Info Summary' widget in Experience builder ??
You'll find the steps in this blog: https://www.esri.com/arcgis-blog/products/experience-builder/local-government/recreating-web-appbuil...
JarrettLivesey1
@AlixVezina
I did play around with this in Experience builder and it just doesn't quite hit the mark, don't know how else to say it.
Thanks for your help with this, your efforts are appreciated.
All the best,
Jarrett
Sunnny
I am waiting for info summary (or near me) widget in Experience Builder for Enterprise Portal.
Is there any chance of that happening?
AzizaParveen1
Hi @Sunnny
Replacement for Info Summary is going to be released in Enterprise 11.3.  the tentative release timeline is early May this year. The new widget name is Near Me.
Once it is available in 11.3, you can follow this blog https://www.esri.com/arcgis-blog/products/experience-builder/local-government/recreating-web-appbuil... to migrate your workflow using the Near Me widget in Experience Builder.
In the meantime you can take a look and get familiar with this using the ArcGIS Online version https://doc.arcgis.com/en/experience-builder/latest/configure-widgets/near-me-widget.htm.
Thanks
Aziza
AzizaParveen1
@JarrettLivesey1 we have added many enhancements including adding map symbols in Near Me in last two ArcGIS Online updates, please give it a try and let us know if anything is still missing.
Sunnny
Thanks for info Aziza
D_AnneHammond
I need to 'Summarize Within' using a selected polygon with polygon overlays and I don't see a way to do that in the Near Me widget...or maybe I'm missing something??
AzizaParveen1
Hi @D_AnneHammond
Are you talking about Infographic widget in Web AppBuilder? If yes, that widget is different from Info Summary. Info Summary does not have any summarize within functionality.
Are you trying to get intersected features using a polygon? If yes, that can be done in Near Me, here is a blog that outlines how to do that in Near Me, https://community.esri.com/t5/arcgis-experience-builder-questions/still-can-t-replace-wab-near-me-wi....
Thanks
Aziza
PAGIS
how can i make the near me summary change based on the user zooming in and out? i have tried setting triggers on the map and the widget and the summary won't change unless you hit "update results". can this be automated to change based on the current map extent?
i'm trying to replicate the functionality from webapp builder and it's not quite hitting the mark. i have a layer set up for clustering in map viewer. i want to summarize three fields from the clustered layer and have it auto-populate based on the user's map extent.
AzizaParveen1
Hi @PAGIS
Right now we don't have the option at this moment, the reason we didn't make automated update default based on extent is because it creates performance issues, however we have plan to add this as a optional configuration parameter in future.
Thanks
Aziza
PAGIS
Ok, thank you @AzizaParveen1 .
Laura
I am looking to create something like the summary widget in webapp builder. This at the bottom is dynamic. Is there a way to do this in EXB yet?
AndreasEugster
@Laura Text-Widget supports connection to data and dynamic content. Maybe you are looking for this - simple example:
  • add a Text-Widget
  • widget-configuation
    • enable "connect to data" in the widget-configuratio
    • select your desired data (and data-view)
  • on the experience-canvas, select the text-widget, dynamic content - define attributes, statistics, expresions to your liking which are then dynamic from you data/data-view (you can also use widget-outputs -> e.g. if you want the dynamic content listen to e.g. a selection of a chart-widget)
William2005
Hello,
I attended the ArcGIS Experience Builder: Migrating from ArcGIS Web AppBuilder session at the ESRI UC virtually.
I found the walkthrough that was done very, very helpful as I have numerous Web AppBuilder that need to be migrated to Experience Builder. I used the walkthrough today to migrate an application. I received an statistics error on one layer through a Table panel. See screenshot.
There are other layers in this particular Experience Builder app where the Statistics function works just fine.
What could be the issue with this one layer?
AlixVezina
@William2005 , I'm not sure, this could be a bug.
I'd recommend either:
  • Logging a new separate Question in the Esri Community, and if you are able to share a link to a sample app with this data where the error can be observed that would be most helpful
  • Contact Esri Support so they can help troubleshoot and recreate the issue for the development team to review
Laura
@AndreasEugster I like that a lot, thank you! How do I get it to change when I zoom in and out?
AlixVezina
@Laura You should be able to setup a Message Action in the Map widget to Filter the data based on the map Extent.
Laura
Thanks @AlixVezina I was looking within the text widget not the map. Seemed to do the trick.
William2005
@AlixVezina thank you for the suggestions. The data in question where the error was occurring was linked to a REST service. So I think we will create a Feature Layer in the future.
William2005
Another Experience Builder question.
Can four web maps be included in one Experience Builder application? Thanks!
D_AnneHammond
Yes, they can be in frames on one page or on separate pages.  Here's an example of experience builder with multiple pages and each page could have its own map:
https://experience.arcgis.com/experience/e0244bab93cf4c7f98180314ec616592/
William2005
@D_AnneHammond thanks so much. I'll take a look.
AlixVezina
@William2005 The Map widget supports adding up to 2 web maps and/or web scenes, and you can easily toggle between them. You can also add multiple Map widgets to one application. Basically, your application can contain as many maps as you would like.
LisaMacgregor
Occasional Explorer
The WAB Summary Widget has the ability to group events on the map and display the number of events grouped at the approximate location. This is the benefit of the Summary Widget combined with its ability to filter events. The EXB Text Widget will provide the WAB Summary Widget's lower banner statistical summaries, but not the graphic summary of events. Please add this group display with the count functionality to Experience Builder. This is preventing us from moving apps from WAB to EXB.
AlixVezina
@LisaMacgregor
To recreate this functionality for Experience Builder, you'll want to setup clustering symbology on your layer in Map Viewer. See: Configure clustering (Map Viewer)—ArcGIS Online Help | Documentation
Tincan
Having one main icon per layer in Info Summary that also acted as a toggle for layer visibility is something I would like to have back. Fairly minor but I'd also like the option to not show the feature details in the widget and use it for selection and show the details in a popup only.
Most importantly I'd like to exclude a layer from analysis when it is turned off in the map. This is currently not possible.
CTR_INTEL
Much like other people have said, the Info Summary Widget, although a basic widget, is very much a staple of the Web Apps that we have built.
I could even go to say it is one of the most important Widgets on our Apps as the data it showed and the way it interacted with the maps was perfect.
I've managed to recreate most of the stuff I need in Experience Builder in a more roundabout and clunky way.
However unfortunately even the workarounds provided above to recreate the info summary widget in Experience Builder just isn't hitting the mark.
The use of a symbol was quite an important feature, especially when you have a lot of feature layers, as it helps to quickly find a layer, so unless I've followed the steps wrong it is unfortunate that you cannot put a symbol on the overall layer like the below, only on the individual items in the layer when expanded. It's good that you can make it update the overall count based on the current map view, however it's a shame you cannot toggle the layers on the map like the Info Summary could do.
The only way I've been able to toggle layers on and off on the map is with the Map Layers widget, however this also does not have a symbol or the count of items.
Is there going to be any more development on this as we may have to look elsewhere for our mapping.
Contributors
About the Author
Alix is a senior product engineer on Esri's ArcGIS Solutions Web Development team, where she delivers innovative web mapping tools for various industries. She's passionate about customer success and combines her knowledge and experience to help solve problems and empower others to develop impactful applications that provide essential functionality.
