ArcGIS Experience Builder 2024 Roadmap
66152
112
01-10-2024 04:56 PM
Labels (2)
Jianxia
51 112 66.2K
Updated on September 13, 2024.
Happy New Year! Here are features planned for 2024. In addition to migrating WAB widgets, we are woking on the Express mode option - a simplified app building experience like Web AppBuilder. We plan to deliver it in the fourth quarter of the year. The planned release dates here are for Experience Builder in ArcGIS Online. New features will be picked up by ArcGIS Enterprise releases later. Keep in mind these features are subject to change please.
112 Comments
JasonBOCQUET
Hi @AlixVezina thanks for your reply. So I'm not able to filter data if they not have the same structure that the other layers?
for example if I want to filter buildings with 5000 square meter of surface; if I want to have the transactions depending on these buildings i'm forced to have a columns about Surface on the transaction table if I want to filter my transactions ?
there is any way to be able to filter a source of data with a common ID depending of a filtered first source ?
AlixVezina
@Tiff ,
 Regarding your question, filtering for null values should be supported as expected when using group filter functionality in the Filter widget once it's released. You should be able to test it out tomorrow. You'll need to use the "is blank" operator and define which fields within each layer you want to filter for null values.
AlixVezina
@JasonBOCQUET, if I understand your question correctly, I believe this will be possible with the group filter functionality, yes. Please check it out tomorrow once the functionality is made available in ArcGIS Online and reach out if you encounter any issues.
Tiff
@AlixVezina  Thank you for the update! Group filters seem to be working well for our first use case.
I have a question about URL parameters. In the general tab, I turned on URL parameters via the "Manage URL status". I see the URL parameters show up in the link, but if I copy and paste into new tab, it remains at default extent. Same with using the Share too where you check maintain URL parameters box, it remains at default extent and draws some sort of square grid around the expected extent. Am I missing a step?
PhilLarkin1
Thanks for being active in these forums @Jianxia
James_Shreeve
Hi @Jianxia ,
In regards to a comment you made in reply to @AndrewSpencer
"@AndrewSpencer Starting ArcGIS Enterprise 11.3 available in May 2024, you should be able to generate reports in Near Me and Print widgets from the printing service. You need to publish report templates from Pro to the printing service, then use it in Experience Builder. Currently this capability is not yet available in ArcGIS Online printing service."
Is there any view to when the capabilities may be available on ArcGIS Online? Specifically referring to the Near Me widget on EB it would just be great to just have the capability to export the full list of features rather than only one at a time grouped by layer. Being able to add unique/organisation templates to the print service on ArcGIS Online would be great, but a basic option now would be hugely beneficial. This functionality is currently available with the Print widget. The Nearby Instant App also allows to print the full list of intersected features inc. map & legend.
Thanks!
CGpp
Hello @Jianxia,
I read that in this ExBD update (1.Q 2024) were added new URL parameters. But one is still missing which I am waiting for 🙂
I need a URL link to find a feature to open map/application. Something similar to Web AppBuilder - query=<layer name>,<field name>,<field value>
example - http://<your portal url>/apps/webappviewer/index.html?id=da80a448ac9246148da0811bddc18c94&query=Census_8491,POP2000,1211537
Is it planned in future releases od ExBD? Thanks for information.
Build custum widget (developer edition) is not solution in my case.
Philip_Ohlinger
@Jianxia Can you tell me if the measure widget planned to come to experience builder in Q2 2024 will support snapping? Right now the measure tool in map viewer doesn't have snapping for some odd reason. This makes the tool almost useless to measure between parcel lines, utilities, etc. Please implement snapping in the measure tool!
kntr
Hi @Jianxia - many thanks for the update with new exciting features like Group Filtering and Image Measurement widgets.
I have one quick question about Oriented Imagery -- do you have a timeline on when ExB will support the new Oriented Imagery data model released with Pro 3.2/Enterprise 11.2? (Similar to the Sidebar Instant Apps template). Thank you!
Ref:
Cheers!
Caitlin_Todd_LCOR
Hello @Jianxia ,
Many thanks to you and the rest of the Experience Builder team for all your hard work in developing this product.
I was wondering if there is, or will be one day, some training for recreating custom widgets in Experience Builder Dev edition?
We have several applications made with WAB Dev edition that contain several highly customized widgets. The person who created them retired and the remaining staff are not as skilled in custom widget creation. We could use some guidance in this aspect for our WAB to EXB migration.
Thanks!
Caitlin Todd
Lane County, OR GIS
ChristopherBowering
Hi @Jianxia,
Thank you for the helpful EB roadmap and for taking time to answer so many of these posts.
The basic viewability (not editing) of related records is the single most paramount function my organization relies upon within our current Enterprise Portal WAB apps.  I'm quite discouraged to see that this function won't even be making it to AGOL EB until Q4 this year, meaning it will be even longer until it is in Enterprise EB (I'm guessing not until at least 11.4 at this rate).  I can't in good faith move our users to EB - which ESRI is strongly encouraging - when this ability doesn't exist.  The fact that WAB is moving closer to retirement and there is no related table viewing function on the horizon for Enterprise is jarring.  I feel as though users in my position are being painted into a corner, so to speak.  It is difficult to keep up with ESRI's recommendations when such vital functions are often lagging behind.
I thought it was important to make this known.  Thanks for all of your efforts!
ChelseaRozek
MVP Regular Contributor
Any hope for a parcel drafter widget?
AmyRoust
@Jianxia - Are there plans to set the Chart Widget up so that it will use domain aliases instead of codes in charts? We have a lot of utility data that uses numbers for domain codes, but would like our charts to display the real-world alias for a more user friendly experience.
Example:
Lifecycle Status domain
0 - Unknown
1 - Active
2 - Inactive
3 - Removed
Right now, if I make a bar chart and group by Lifecycle status, I get groupings of 0, 1, 2, and 3 instead of Unknown, Active, Inactive, and Removed. There doesn't appear to be a way to override that by typing in aliases manually.
barryguidry1
barryguidry1
Jianxia, is it possible to show directions from within the Near Me widget, as was in WAB, instead of the need to use the Search widget or click the location on the map?
AzizaParveen1
Hi @barryguidry1 right now, we don't have the support for calculating direction in Near Me, but it is planned and scheduled to  be available in Q2/Q3 update of ArcGIS Online. It will work in a little different way than WAB, you will be able to send to and from locations to Direction widget from Near Me and show  direction in the Direction widget.
stariq22
@Jianxia do you when the features planned for Q2 would be released? Really excited about the measure widget!
by Anonymous User
Not applicable
@Jianxia you mentioned more URL parameters coming.  Is there a proposed list of ones that would be supported or a priority on them.  Having the version for the branch version widget and one to set the parameters of a filter widget would be really valuable.
AlixVezina
@Anonymous User Please could you elaborate on how you are using the version in a filter in your post? Thank you!
MelindaMuzzey
Hello! Wondering if there is already a date for the Situational Awareness Widget to be integrated into Experience Builder within ArcGIS Enterprise? We just got notification that Web App Builder is going away, and all of our apps utilize the situational awareness widget.
Thank you!
yrpEH
The Situational awareness is not being replaced. There are blog posts about how to use the 'Near Me' widget in ExB to create a similar widget as a workaround. Their emergency management widget migration/replacement is very poor...
MelindaMuzzey
@yrpEH sorry I wasn't clear . Web app builder IS being replaced. Enterprise version of experience builder does not yet have the near me widget which is needed to utilize the situational awareness. So I'm asking if there's a roadmap/timeline for that yet since this post is in relation to experience builder upgrades. Hope that makes sense. Thanks!
by Anonymous User
Not applicable
@MelindaMuzzey this link Web AppBuilder and Experience Builder functionality matrix—ArcGIS Web AppBuilder | Documentation has the migration status of each WAB widget and the relevant version it is implemented/planned for the various versions  (AGOL, developer, Enterprise) of EXB.  Also shows which ones aren't being migrated and alternate options
MelindaMuzzey
@Anonymous User awesome! Thank you so much.
SIKACINE
New Explorer
Hi @Jianxia I had a question on the road map for Experience builder and the "Add Data Widget", will some of the file formats in WAB become available in EB. It's a common request from CAD users, it's not currently an option to load. Thanks
jmarquis
New Explorer
Hi @Jianxia,
Will the Batch Editing capabilities include exporting features or just updating attributes? I am looking for Experience Builder to have some functionality in which I can export multiple features selected into a single (or multiple) csv's without having to manually click "export" on each record/layer I have selected by the Near Me widget.
Jianxia
@SIKACINE , which file formats do you want the Add Data widget in ExB to support?
Jianxia
@jmarquis , you can use the Select widget to select multiple features and export them to a CSV file.
by Anonymous User
Not applicable
@AlixVezina with regards to my post about URL parameters and versioning...they would be two separate URL parameters not using the version as a filter.
  1. Version - URL parameter to set the version and this would apply to the branch version widget and therefore related layers on the map.
  2. Filter - URL parameter specifying which filter widget to set and the condition to set for the filter.
AlixVezina
@Anonymous User
There is a URL parameter available for setting the version. When you add the Branch Version Managment widget and switch versions, you'll see the version update in the URL. See: Change the geodatabase version of a data source | Documentation
You'll find documentation regarding the URL parameter to filter data sources here: Filter data sources | Documentation
These are separate paramaters.
by Anonymous User
Not applicable
Hi @Jianxia, are we still expecting a Q2 release for EXB or is the timeline being pushed back? Thanks.
AntonTymoshenko
Good day, @Jianxia, are there any updates regarding Measure Widget, any information about release? Is it possible to test it on a prerelease version?
AlixVezina
@AntonTymoshenko The new Measurement widget is now available with the latest update of ArcGIS Online in June 2024. See: What’s New in ArcGIS Experience Builder (June 2024) (esri.com)
AntonTymoshenko
@AlixVezina Thank you for the reply. I'm already using this widget and my main issue is that I can't edit colors of the lines and polygons on the map. I'm using ArcGIS Maps SDK for JavaScript and so far I didn't find any properties responsible for the colors or wasn't able to override colors on the page.
GWS_RichardW
Hi @Jianxia ,
Back in 2022, we were told that there was no plan to migrate the cost analysis tool into EXB because that functionality could be supported by Arcade expressions. We're nearing Q4 2024 and Arcade support is still only "under consideration."
A number of apps that I've built for my organization rely quite heavily on Arcade and looking through the EXB message boards, there seems to be a lot of desire for this functionality. Can you share with us why that hasn't been added to the Roadmap yet?
SimonKIMO
New Explorer
Hi @Jianxia , do you have an update on Batch Attribute Editing and if it is still due in Q4? We are migrating all old Web App Builders to Expreience Builder and without this common widget its difficult to replace the functionality. Thanks.
JasonBOCQUET
Hi @Jianxia i see your update of the roadmap (Q4)
Custom Filter in Filter widget gonna looks like the custom filter in the List Layer Widget ?
What is the "Accordion layout widget" ?
And last question "Subtype group layer"can you tell me more precision about this feature ?
MarkEastwood
Looks like Batch Attribute Editing was removed from the Road Map... Any updates on when it will be released?
AdamGebhart
@JasonBOCQUET
I'm guessing the Accordion Layout widget will be similar to what was asked for at https://community.esri.com/t5/arcgis-experience-builder-ideas/add-an-accordion-widget/idc-p/1503238
ScottStepro1
@Jianxia  batch editing please.
With all due respect, I do not expect an answer. Clearly this must be an unsolvable bug at this point.
Along with many others here I have made mention of it time and time again for going on 2 years.  I brought it up with folks manning the UC EB booth at both the 2023 and 2024 UC and was given the standard "working on it, Q4... next Tuesday... soon as I eat this orange" type responses. Frankly, its quite frustrating that esri has not solved the issue keeping the functionality from EB after so long.   Folks on these forums have been requesting batch editing since the dawn of EB while esri ties our hands to a scuttled ship (web app builder).  Please pause in putting out new widgets, solutions etc. and fix the applications you have in circulation.
Its a great app for the most part but this bug is a deal breaker.
@ChaseFisherGIS @DanHaag @JohnBorisenko
ElliotS
Occasional Explorer
Draw Text tool - long anticipated addition. Can't wait.
jcokin1
Thank you @Jianxia Song and to the rest of the WAB / EXP Builder team!👍
Looking fwd. to seeing what other updates get pushed out here in Q4.
So happy to see that an express mode is being built as part of the future roadmap. This is a great idea and will help greatly in the transition from WAB to EXB.
Some very lively discussions (within the GIS community) regarding EXB at the 2024 UC this past July 🤣
Thanks again!
ÉmilieLamontagne
@Jianxia good news for the URL parameter for zoom to features by attributes. We are highly need a functionnal method parameter in order to migrate our Web app builder (WAB) to Xp Builder. At this time we are a stand still since XP Builder does not pan and zoom to the feature layer record like what we can do with WAB URL & find = with a feature service
Will this enhancement replace & find = sucessfully
fklotz
The Batch Attribute editing tool was on the Road Map for 2024, but it has since been removed. However, according to the Web AppBuilder and Experience Builder functionality matrix (as of 2024-10-16) it is still "Planned for 2024". Hopefully this means it will arrive soon and our WAB apps can finally be fully ported to EB. @Jianxia is it going to be a Christmas present? 😁 Has the EB Team gotten enough of the Maps SDK for JavaScript Team's time to get it working?
Henry_PeleshBW
@Jianxia What happened to the "Batch Editor" widget for Q4? Has this been delayed?
Thanks! 🙂
Henry
Mike_Frates
@Jianxia Any word on the batch editor widget? Thanks!
jmaxwell_braun
@jiangjian I am also curious about the batch editor widget disappearing from the roadmap. It is badly needed and causes ripple effect issues since we have to keep using WABs. It's holding us back from implementing new functionality to our users.
Jianxia
@fklotz @Henry_PeleshBW @Mike_Frates @jmaxwell_braun - thanks for dropping the notes for the batch attributes editing. Unfortunately, this feature is now postponed to Q1 2025. We will update the documentation to reflect the new timeline.
wcozzens
The Batch Edit widget is also high on our list - cannot move off WAB until that is available in ExB.
The other item is the standard Edit widget in ExB does NOT have the same capabilities as the Smart Edit widget in WAB. Most importantly the ability to copy a feature/attributes to a new feature - this is another significant roadblock to moving to ExB from WAB.
Tiff
Chiming in also to say that batch attribute editing is very important for our organization as well. But also want to emphasize that this functionality needs to come with a "Save" or "Apply" edits button. Right now a single cell can be updated in the ExB table and once you enter, it's applied automatically. For batch attribute editing, there is a larger potential for human error and prompting users to apply edits instead of automatically applying them is extremely important!
Contributors
About the Author
Product Manager for ArcGIS Experience Builder and ArcGIS Web Appbuilder. She likes camping and hiking.
