Will adding a domain affect schema for service on ArcGIS Server?
1791
07-25-2023 12:49 PM
JoshBillings
I feel like this is a simple question, but I don't know this off the top of my head as this will be my first time performing this.
I have a layer that is part of a Map Service on ArcGIS Server. This layer needs to have domains added to one of its fields. If I add the domain in Pro and republish the service, will this domain addition affect the schema and therefore anything using the service?
Josh
Tags (3)
MarceloMarques
It will not affect anything.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
MarceloMarques
ZachBodenner
MVP Regular Contributor
Yeah it will. Once there's a domain present the behavior of the service changes so that you'll have a dropdown selection, kind of like in pro. I have had a bit of trouble getting the changes to actually stick when overwriting a service after adding a domain. You might need to run the overwrite process multiple times.
All of that said, adding a domain is pretty non-disruptive. It'll change how users can interact with it, but it shouldn't have any concerning side-effects unless you'd been using that data field as the symbology driver.
Happy mapping,
- Zach
