Why not cluster in ArcGIS Enterprise 10.5.1?
621
09-18-2017 08:20 AM
Juan_ManuelAngel
Good morning, it is possible that somebody will answer me technically because in ArcGIS Enterprise 10.5.1 version it is not recommended to develop cluster as it says in a document that was published of UC 2017 of the architecture of ArcGIS Enterprise, Thank you very much.
JonathanQuinn
Esri Notable Contributor
In many environments, clusters have caused too much inter-machine communication which made the deployment unreliable and under-performing.  The recommendation is to have a single cluster, (which is the default for new deployments at 10.4).  If you need clusters to separate workloads for certain machines, separate sites should be used.
