What might cause the services to stop as the machine restarts?
Jamal
Good question Jamal.
It happens to us occasionally. In my environment, I have several virtual machines at play with one single map service. SDE, Web Server, ArcGIS Server(s). When it happens to us, my guess is that it is a result of server patching and not starting the virtual machines up in the correct order.
If your environment is distributed, then start the database, then ArcGIS Server(s) then your web server.
If your environment is all on a single server, then I would ask whoever manages your servers what they did recently. Very rarely we have problems with the SDE machine where the SQL Server service starts, but not the Agent (and that is bad because backups don't run). I suspect that problem is related to all of the server monitoring software that our data center installs, but I can't prove it.
If you're able to connect to AGS in ArcCatalog or in Server Manager alright (which, from your screenshots it appears as such), then in my mind the "SOM" or the ArcGIS Server service is running just fine. That being said, I think the only reason a service might stop or never start is if there is an issue connecting to the underlying data sources. Since your data sources are file geodatabases local to the server, it's hard to believe that would be an issue but you never know. Can you check your ArcGIS Server log to see if there are any errors that might point to an issue? Can you also check your Windows Event Viewer for problems right after the machine boots up?
I don't think anyone really knows; hence the length of this thread. I will reiterate my questions...
Thanks William
I�??ll be checking the logs of ArcGIS Server and Windows the next time I get this problem
[ATTACH=CONFIG]29901[/ATTACH]
From the looks of your screenshot for ArcGIS Server Manager, you will most likely need to change the logging level filter to ERROR or somehting more granular to see the issues. Make sure you've set the logging level to actually record at ERROR level or better. Good luck!
Can you check c:\arcgisserver\logs\JAMAL-SONY\errorreports to see if an error report was produced per the messages in the log?
