Webgisdr file to clean walarchive in HA
1650
03-08-2019 04:27 AM
GustavoDrets
In our infrastructure we have two Portal for Arcgis machines in High Availability. We have being monitoring the size of the directory C:\arcgisportal\backup\walarchive.
We have read that webgisdr reduces its size removing database logs. But the point is that after running webgisdr it truns out that the directory has 84 MB in one node  and  2gb Gb in the other
Any idea about what is wrong?
Thanks for your help
GD
Tags (1)
JonathanQuinn
Esri Notable Contributor
Unfortunately the DR tool doesn't delete the walarchive logs on the standby machine when it's run at this time. You'll need to delete them manually. We'll correct this in the software.
DavidHoy
Jonathan Quinn
Jon, has this made it into a release yet?
JonathanQuinn
