PUblish ArcGIS Services in multiple environments using a single SD file
1223
10-22-2020 05:43 AM
CrossrailGIS
Hi Everyone,
We have ArcGIS Enterprise in multiple environments - DEV, STA, and PROD, and 3 oracle databases per environment with same schema and layer names. I am looking for a methodology to publish services in multiple environments using a single MXD and a SD file. I am sure there are some ways to that, so that we don't need to create 3 MXDs per each environment and publish them separately. If anyone has done this before or have knowledge, i would be grateful to know.
Many thanks,
Sushil
JakeSkinner
Esri Esteemed Contributor
Hi Sushil,
You will need 3 separate MXDs referencing the correct Oracle instance, and then create the SD file.  I worked with a customer where we did something similar.  We had a script that would copy the MXD to the desired environment, remap the MXDs layers to the other Oracle instance, then publish the service.
CrossrailGIS
Hi Jake,
Thanks for your response. This sounds exactly what we are looking for i guess. Is the script shareable to have a look, i have not seen that sort of scripts?
-Sushil
