WebApp Builder struck in a loop after modifying the token expiration time
604
04-28-2026 06:48 PM
wizgis
Hello Community,
I have observed a rather odd behavior where if we modify the maxTokenExpirationMinutes property from /portal/sharing/rest from -1 to 10 or some other value and logout from /portal/sharing/rest and then log back in to /portal/home and create an application using WebApp builder, it just loads in an endless loop.
Once I set the token expiration back to -1 then the WebApp builder loads as expected. I have tested this in 10.9.1 and 11.5.
Was wondering if this is an expected behavior
GlenterpriseUK
Hi @wizgis,
I think you might be encountering this BUG-000148016 for Portal for ArcGIS. I would advise you to reach out to Esri Support.
Regards,
Glen
GlenterpriseUK
Hi @wizgis,
Regards,
Glen
wizgis
Thank you @GlenterpriseUK . This helps
GlenterpriseUK
Always happy to help @wizgis
Take care,
Glen
