Web Print Task and the Legend
2599
08-21-2012 05:08 AM
LemvigKommune
Hi, is it possible to set the legend for the Web Print Task to use the Map Extent Option, so it only shows those classes that are currently visibly on the map ?
If any has the solution for this, I would be glad to see something written with screendumps in it. 😉
Thanks
Mads Gren
Denmark
PeterYurkosky1
If the legend is for a service layer, it is not possible. The legend will show all of the layer's symbols, regardless of the current extent. If the legend is for a client-side graphics layer, we enable this setting for you, so yes: the legend will show only the symbols that can be seen in the current extent.
