Web Adaptor properties file on 10.1 (unix version)
2624
17
10-31-2013 10:25 AM
DaveWeiss
After installing the webadaptor on 10.1 (unix) I have tried to configure it. I get an error that says "Unable to register the GIS Server with the Web Adaptor". Also, there is an error in tomcat saying it was unable to open the web_adaptor.properties file. Where should that file be and what should be in it? Thanks.
JustinRodriguez
Hello,
Are you able to get to your server via port 6080 from you web server in a browser?
Also, I have a Windows Java install, and I cannot find web_adaptor.properties. Do you know the general path to this file? Thanks-
Justin
DaveWeiss
Yes, I can get to the server using port 6080.
I think the properties file would be in the tomcat webapps directory tree somewhere. There are other properties files in there. I was thinking that the Web Adaptor install should create it or copy it but that doesn't seem to have happened.
JustinRodriguez
Hello Again,
Have you tried just uninstalling and reinstalling web adaptor? Thanks-
Justin
DaveWeiss
Yes, I just tried again. Uninstalling and then reinstalling the Web Adaptor.
The Web Adaptor is 10.1 SP1. I think the ArcGIS Server is also. The software authorization page shows the software version as 10.1.1.
JustinRodriguez
Can you navigate to this endpoint:
http://<arcgisserver>:6080/arcgis/rest/info
Can you tell me what it says in current version and full version please? Thanks-
Justin
DaveWeiss
Justin
Server INFO
Current Version: 10.11
Full Version: 10.1.1
SOAP URL: http://<myserver>:/arcgis/services
Secure SOAP URL: null
Authentication Information:
- Is Token Based Security: true
-Token Service URL: http://<myserver>/arcgis/tokens
-ShortLived Token Validity: 60 minutes
JustinRodriguez
Thank you very much for the info,
So there is a reverse way to do this. Try to navigate to http://<myserver>:6080/arcgis/admin and navigate to
Home > system > webadaptors. From there, try to register the web adaptor. Please see if you get a different error. You can try turning on verbose or Debug level logging and include any errors you might find.
Thanks-
Justin
DaveWeiss
When I go to the http://myserver:6080/arcgis/admin page and navigate to the webadaptors page it shows that the webadaptor is registered. So apparently it did it even though I got the error. Maybe I'll try a few things there and see if I can figure out what is going on.
DaveWeiss
While the server believes the web adaptor is registered the web adaptor side does not.
If I go to http://myserver:8080/arcgis/webadaptor I get the page to configure the web adaptor and at the bottom it says "Status: No GIS servers are registered with your Web Adaptor".
Any suggestions?
