Web Adaptor 10.4.1 will not register with ArcGIS for Server 10.4.1
2427
06-01-2016 04:24 AM
MiguelParedes
Greetings all,
I have just installed ArcGIS for Server 10.4.1 (workgroup) on a clean, new VM (W2012R2), All is working well. A certificate has been installed And all's well. I can publish and consume services without an issue.
I have installed the ArcGIS WebAdaptor 10.4.1 (WA) on the same machine. Called it Obi (after my Habaneese), and using https.
When it comes time to register the WA with Server, I am getting the following error:
Has anyone experienced this issue?   I have installed the WA since 10.3.1, and 10.4, a few times, but never had this issue.
I have tried, uninstalling/reinstalling, make sure I have all the necessary IIS requirements, etc. Nothing seems to be amiss.
Thanks in advance for any input.
Miguel
MiguelParedes
Closer scrutiny has revelled that, my server installation was actually 10.4, and not 10.4.1.  I must have clicked the wrong install file, given that both 10.4 and 10.4.1 coexisted in the same directory location.
So the learning points here:  The WA identifies correctly when it is being register with a version that does not correspond to it.
Miguel
MiguelParedes
Miguel
