Web Adapters server on Default Web Site must be removed after I uninstall ArcGIS Enterprise Builder.
1048
11-09-2021 04:41 AM
IaraNascimento
I had to uninstall ArcGIS Enterprise Builder to reinstall because I was sent the wrong Portal for ArcGIS license.
When I ran ArcGIS Enterprise Builder again, the following message appeared: Web Adapters server on Default Web Site must be removed.
On the Default Web site there is no longer the indication of ArcGIS Web Adapter in Applications Tools, because I removed it. I uninstalled everything from ArcGIS, but there were some folders that were not removed when uninstalling, should I remove them? Need help!!!!
See pictures attached!
Thanks, Iara
IaraNascimento
I discovered that the solution is to delete c:\inetpub/wwwroot folder.
