Using Living Atlas 3D scene in Enterprise
951
12-05-2023 03:51 AM
AnneTetley
I'd like to use the OpenStreetMap 3D Buildings and Trees Scene layer in Enterprise, I don't see a way to bring the scene in as I do other items from the AGOL Living Atlas.  Is it possible?
Anne
David_McRitchie
Apologies! I have fixed the link now. That is odd so I would email osm@esri.com to flag this.
You could take the URL to the service and add it as an item to your content. That might provide a workaround.
Many thanks,
David
Esri UK -Technical Support Analyst
David_McRitchie
Hey Anne,
I believe this wont be available unless you are using Enterprise 11 or later based on the following comment on the item page for OpenStreetMap 3D.
Hope that helps,
David
AnneTetley
Hi David,
We're using version 11.1 of Enterprise, so should be OK?
I can't follow the link as its tech support specific..  could you link again to the comment?
Thanks
Anne
That link takes me to
David_McRitchie
Many thanks,
David
AnneTetley
Thanks David, that link worked to bring the Trees and Buildings layer in, just need to find the correct relief basemap with a matching WKID to go with it 🙂
