Upgraded from ArcGIS Enterprise 10.9.1 to 11.1 - Signout URL is redirecting to 404 Server Error
324
02-02-2024 10:02 AM
SH013
We just finished upgrading from ArcGIS Enterprise 10.9.1 to 11.1, and there's a bit of a hiccup that's bothering us. When a user logs out using their Enterprise Login via the Microsoft Azure Portal, they're signed out but immediately gets a redirect to a 404 error page that says 'File or directory not found.' Oddly enough, this wasn't an issue in 10.9.1 but has popped up in 11.1. Has anyone else run into this? Any insights or fixes would be greatly appreciated!
Tags (3)
SH013
It has been confirmed that this issue was a bug in version 11.1 and has been resolved in version 11.2 (Reference: BUG-000165238)
When ArcGIS Enterprise Portal is configured with SAML (Azure AD) and in Azure the Logout URL is set, upon signing out users will get a server error 404 – File or directory is not found instead of the Portal Sign Out page
Workaround solution is to leave the logout URL blank in Azure AD.
DanielBrumm1
Occasional Contributor II
This is a total guess, but I assume you are using SAML logins? Did you check the logout url setting and make sure it is still valid?
Also, maybe try clearing your browser cache.
Daniel Brumm
GIS Nerd
SH013
Yes it is a saml logins and I have checked the logout url setting and it is valid 😞
SH013
