Update popup of DEM Imagery layer from labelling as service level pixel - possible in map viewer classic, how to do this in map viewer
149
06-04-2024 02:24 AM
GISNCC
New Contributor II
I have published a DEM layer as an imagery layer to ArcGIS Enterprise.  I want the user to be able to click on a point on the map and return the elevation level from the DEM.
I can get this to happen however the value is labelled as the service pixel value.  I want to update this to something more meaningful.  In Map Viewer, the popup configuration is greyed out.
 If I open the map in Map viewer classic, there is the option to configure the popup and I can change the service level pixel text to what I want.  Is there a way to do this in map viewer?  I have a large organisational web map that has been set up in Map Viewer so I am hesitant to swap to map viewer classic for this change in case it impacts something else that has been set up in the new map viewer.
Thanks very much,
