Unable to start PublishingTools on ArcGIS Server 10.1
2018
04-28-2017 09:49 AM
DannyIm
I tried updating my ArcGIS server 10.1 to use SSL following the instructions here. However, I wasn't able to get that to work and I reverted the change.   Now, my installation is running into an issue where I cannot publish any more services.  The PublishingTools service is stopped and when I try starting it I get an "ERROR: service failed to start, No resource could be found at that address" message.
I also see these messages in the logs:
"Error while processing catalog request. AutomationException: null"
"ServiceCatalog failed to process request. AutomationException: 0xc00cee3a"
Any ideas on what's going on?
Thanks!
DannyIm
Ok, so I figured out my issue.  When I enabled "http and https" it looks like ArcGIS server updates a tomcat server.xml configuration (located under Server\framework\runtime\tomcat\conf) and adds a new Connector element to the file, with the secure endpoint.  When I reverted the change back to "http only" my server.xml file somehow retained that connector and so http was still redirecting to https, which is what I believe was causing the issue with the PublishingTools not starting up.  I removed the https connector, restarted arcgis server and the PublishingTools service was up and running again.
JonathanQuinn
Esri Notable Contributor
I'm glad that you were able to sort out the problem, but I suggest you start planning the migration to a newer version of the software as 10.1 will no longer be supported after January 1st, 2018.
http://downloads.esri.com/support/product%20life%20cycle/server_gis/ArcGISServer_PLC.pdf
