Unable to see the Create button in arcgis Portal
413
07-24-2019 07:15 AM
vijaybadugu
Unable to see the Create button for the administrator user. if i try to create Hosted feature layer with publisher user, i am getting "Dataset not found"  error i am using 10.7.1 Products
DerekLaw
Esri Esteemed Contributor
Hi Vijay,
Can you please be more specific? Are you saying the "Create" button does not appear in the Portal for ArcGIS website when you're logged in as an administrator? Is this on the Content page? on a web map item page? In the Map Viewer? Can you please post a screenshot(s)?
Can you please verify that you've deployed a Base ArcGIS Enterprise deployment? So you have the ArcGIS Data Store installed, with a hosting server?
Base ArcGIS Enterprise deployment—ArcGIS Enterprise | ArcGIS Enterprise
Hope this helps,
