Unable to Connect to Azure SQL Database
11015
11
09-08-2020 10:22 AM
MichaelMirobelli
We are unable to connect to an Azure SQL Database (12.0.2) through ArcGIS Pro (2.4 & 2.6.1), we are using the most recent Microsoft ODBC Driver 17.5.2. We are trying to publish/ share the content to our On Prem Enterprise Hosting server (10.8).
We are receiving the following error:
"Connection Error Failed to connect to the specified DBMS instance. A database connection exception has occurred. Connection was attempted with an older version of SQL Server client communications software that is not supported."
Derek Law
MichaelMirobelli
George Thompson‌ & Shannon Shields‌ Thank you both for all of the assistance so far.
Do ArcGIS clients currently support connecting to Snowflake or Azure Data Explorer? I know that geodatabase support is not currently enabled in either, but we just need to be able to create a connection to the data source and pull non-shape data from it.
DanMcCoy1
