Unable to add fields to Hosted feature Service using REST call
1746
04-16-2018 11:56 AM
SreedharBalerao
am new developer to ESRI AGOL,
I am able to
1) Upload ShapeFile
2) Publish ShapeFile as a HostedService
Now I need to add few extra fields to the featureService layer.
I tried to post fields collection to
/addToDefinition end point,
response is Success, but when I check the featureService layer in AGOL portal, I do not see the newly added fields
Any suggestions please
SreedharBalerao
Any Suggestions please? Bumping it
SzymonPiskula1
Perhaps you got the syntax of /addToDefinition wrong and the field should be somehow differently nested in your JSON payload? Different array/attribute name. Deeper in the payload tree etc?
SarahScott3
Can you tell me a little bit more about your workflow?
What does the JSON you're using in the addToDefinition look like?
