Hello All,
We have the following architecture:
Machine A: ArcGIS Server & ArcGIS DataStore
Machine B: Portal for ArcGIS, & WebAdaptors of Portal & Server
Our portal & server is publicly accessible. Recently, we observed that we are able to access portal publicly however, on trying to access server manager publicly we get the following error as shown in the screenshot.
Things that we have checked
Further it was observed that when we try to access server & portal through the FQDN of the webserver machine on which WebAdaptors are installed, portal is opening successfully however, server is still not opening. Attached is the screenshot
On researching on this further I came across the following link : Solved: Reconfiguring WebAdaptor for Portal - Esri Community
It was solved by uninstalling & reinstalling webadaptor. Hence, just wanted to know if that is the only way to resolve this issue or there is something that can be checked. Also, if uninstalling & reinstalling is the only way would anything happen to the existing services published to the server site.
Any inputs would be great .
UPDATE
Thank you @CodyPatterson @JakeSkinner for your suggestions.
The issue was resolved after uninstalling, reinstalling & reconfiguring webadaptor of ArcGIS Server.
Hey @wizgis
Is your web context URL set up to support this external URL? I have mine set to mimic what my public URL would be: https://<public-url>.com/server
Cody
@CodyPatterson Am not sure about that. Is there any way this can be checked?
Hey @wizgis
This is what I see here:
And is located here: https://<server FQDN>/server/admin/system/properties
You should be able to see the URL in the WebContextURL section.
Cody
Hi @wizgis, when configuring the web adaptor, did you check the following option?
This will allow you to access ArcGIS Server Manager through the web adaptor. If this is not checked, you can only access the web adaptor through https://<FQDN>:6443/arcgis/manager. You can run the web adaptor again with this option checked to reconfigure.
Am not sure on that as well as someone else had configured the environment earlier. I was under the impression that the if this particular option is unchecked then, one would still be able to access manager & rest serviced endpoint and won't be able to access admin endpoint.
Please let me know if my understanding is incorrect.
You won't be able to access Server Manager through the Web Adaptor URL if Administrative Access is not enabled. You can check in Server Manager by going to Site > Web Adaptor:
UPDATE
