Token authentication fails randomly for integrated applications.
603
12-09-2025 08:36 AM
TalluruRangaVital1
Token authentication fails randomly for integrated applications. What is issue?
VenkataKondepati
Honored Contributor
Possible Root Issues
System clock skew between Portal, Server, IDP
Load balancer sticky sessions disabled
WebContextURL mismatch in clustered environment
Expired certificate signing the SAML assertion
HTTP→HTTPS redirect rewrite errors
Regards,
Venkat
Follow me on: LinkedIn
If this response helps or is the solution to your post, please consider marking it as a solution
VenkataKondepati
Honored Contributor
Regards,
Venkat
TalluruRangaVital1
Thank you.
