The connection property set was missing a required property or the property value was unrecognized. Invalid database name (Postgres)
1492
10-06-2021 11:20 AM
rajeshkumarg1
While we are trying to register the database on ArcGIS Server, we are facing the below issue. Meanwhile we are using Postgres as RDBMS.
Installations:
ArcGIS Pro 2.8,
PostGreSQL 12.4.1
ArcGIS Enterprise 10.9
WellingtonChristian_Rodrigues_
Have you tried to create a new connection on ArcGIS Pro before publishing the data?
Have you validated the connection on ArcGIS Server? Like Server Manager > Site > Data Store > Validate
rajeshkumarg1
I tried for new connection and validating the database connections in ArcGIS Server but still i am facing the issue.
sapnas
What is your server name? If you are unsure on the machine name then use your ip address. localhost stands for local computer.
Based on your string connection we need  to now:
Where is your AGS?
Where is your data base server?
Where is your ArcGIS Pro?
Did you check your firewall?
