Stand alone server upgrade - Do I need a Data Store?
6003
10
01-04-2022 09:57 AM
ZachBodenner
MVP Regular Contributor
Hello,
At some point in the not-too-distance future I plan to upgrade a stand alone ArcGIS Server from 10.6.1 to 10.9.1. The server is not part of our  Enterprise base deployment and so is not federated with portal.
Examining what is currently installed on the server machine itself, I have an installation of Desktop 10.6.1, Server 10.6.1, and Data Store 10.8.1. When I open the Data Store configuration wizard, it says that it is currently configured as a relational data store and links to our Portal Site (which is 10.8.1). However, I can't find any other installs of Data Store that are configured with the stand alone server.
I've consulted ESRI's documentation but so much of it is focused on the Enterprise/Portal/Federated deployment model. The best I can find is this nested section on upgrading a single machine site (https://enterprise.arcgis.com/en/server/latest/deploy/windows/upgrade-arcgis-server.htm#GUID-3F92EFC...) that doesn't seem to reference a Data Store, and this documentation (https://enterprise.arcgis.com/en/server/latest/install/windows/single-machine-deployment.htm) that doesn't mentioned Data Store either.
So...do I actually need a Data Store installation for a stand alone server? The data referenced on the server will be coming almost exclusively from enterprise geodatabases - I don't believe it will need hosted feature layers, but does need to be able to have cached image map services. I'd like to avoid a situation where the server upgrade goes mostly smoothly but gets tripped up because I couldn't figure out ESRI's documentation.
Happy mapping,
- Zach
ReeseFacendini
Esri Alum
A standalone ArcGIS Server installation does not need ArcGIS DataStore to be configured.  ArcGIS DataStore is used only within a fully deployed ArcGIS Enterprise, and only Portal for ArcGIS can created hosted layers, so all data within a standalone ArcGIS Server needs to be referenced either from disk or an Enterprise geodatabase.
ReeseFacendini
Esri Alum
ZachBodenner
See now why is that so hard to put in the documentation somewhere?
Happy mapping,
- Zach
JamalNUMAN
Legendary Contributor
What is the function of ArcGIS Data Store? What are its benefits?
Jamal Numan
Scott_Tansley
JamalNUMAN
I got this video that explains the functionality of “data store”,
https://www.youtube.com/watch?v=_LFzszE6bKc
When publishing data with ArcGIS Online, there is no option to reference (register) the data to avoid copying it to the server, and thus it’s compulsory that the data will be copied to cloud! I think that the “data store” has the same functionality; it’s equivalent to copying the data to cloud
Jamal Numan
Data is an integral part of GIS, providing the foundation for your mapping, analysis and decision-making workflows. Where you store your data impacts how you access, edit, validate, secure, and scale it. This session will highlight storage options available using ArcGIS Enterprise, including ...
Scott_Tansley
Basically, a base deployment of ArcGIS Enterprise is conceptually the same as the core offering of ArcGIS Online.  A server, connected to a datastore and fedarated with a portal allows you to create hosted feature layers, and some other options, the same as AGOL.  The difference being that it's your infrastructure and you manage it.
The reference concept is no different to the traditioanl model of using an ArcGIS Server, which I believe you have an use.
Many people still use an ArcGIS Server to support their ArcGIS Online operations.  It's actually very sensible to have a separate ArcGIS Server to work alongside your base deployment, and then don't referenece data on your hosting server:
https://enterprise.arcgis.com/en/get-started/latest/windows/additional-server-deployment.htm#ESRI_SE...
In this way you treat the base deployment 'server' just like you would AGOL, and the 'other' server like a traditioanl one.  I'd recommend federating though to get the security.
Scott Tansley
https://www.linkedin.com/in/scotttansley/
JamalNUMAN
But if the ArcGIS Server is federated in the Portal which allows referencing the data, then what is the benefit of ArcGIS Data Store?
Two cases:
  • Referencing the data allows publishing the data without the need to physically copy it to the server.
  • Copy all data: allows copying the data to the server
Then what’s the difference between the “ArcGIS Data Store” and “Copy All Data”? they are performing the same sort of functionalities
Jamal Numan
Scott_Tansley
Referenced data is published as a Map Service or Map Image Layer, depdning on preferred terminology.  It uses an older publishing technology that uses ArcSOC.exes on the server.  Each uses memory and has a compute footprint.  All of that means that architecturally you can only scale so far, i.e. deliver a finite number of map services.  You can make those map services into feature services for editing, but you use even more memory etc.  If you're using Dedicated Service Instances then ~100 is the arbitraty max number of services from a single ArcGIS Server Site.  If you use Shared Instances then you can have hundreds of services.
Hosted Feature Layers can only be provided from a base deployment of ArcGIS Enterprise, it needs the Portal, Hosting Server and Data Store.  Put them together and you have a lightwweight architectural paradigm that could allow you to stand up 10,000's of individual services.  However, you're presenting data not maps, subtle but important difference.
Also some functions inside of a Portal (analytics/Insights) use Hosted Feature Layers as temporary storage.
Basically, if you want to use Enterprise, you need a Data Store.  It's down to you how you publish.
In summary, Hosted Feature Layers from the Data Store scale better.
Scott Tansley
JamalNUMAN
Till now, I couldn’t figure out the function of ArcGIS Data Store. How can I touch its benefit?
For example, in the screenshot below, what is the difference between publishing the “electricpole” service with or without having the “ArcGIS Data Store” configured?
Jamal Numan
