see http://wiki.gis.com/wiki/index.php/Server_Software_Performance
After days of troubleshooting the services I finally called ESRI Tech Support. They determined that everything was fine with my server and my services but there was definite heavy SQL usage. So, their database team called me and seemed to instantly know what my problem was. It was the new "DEFAULTS" value for GEOMETRY_STORAGE in the dbtune table. In previous versions it was set to SDEBINARY, now in 10.1 it is set to GEOMETRY which is slower. I recreated my database feature classes using the SDEBINARY for the spatial type and everything is back up to the same speed as it was in 10.0
I used the sde command line tools to change the default setting to be SDEBINARY so that future feature classes that are created will use that. If we find that we need GEOMETRY for the spatial storage type we can always select it.
Luci
Hey Jamal,
We thought about going back to a file geodatabase but decided against it. Some of our users wanted to be able to do tasks in our web app which would require a feature layer. Because feature layers are only supported through SQL, we would have had a portion of our data in a SQL GDB and a portion in a file GDB and that would have been too much to maintain. So far we are happy with the speed we achieved just by changing the spatial data type from Geometry to SDEBinary.
We have an end of the day cleanup where all users reconcile/post and remove their versions. The data is then QC'd, reconcile/post to Default, Synchronized and the geodatabase is compressed. We Analyze about once a week. Having a good cleanup routine definitely helps with the speed of the geodatabase.
Good Luck!
Luci
