Server admin connection in Pro ?
18475
23
10-01-2019 01:16 PM
by Anonymous User
Not applicable
I'm configuring a new enterprise deployment and have some limited experience connecting to a standalone server prior to 10.6.1. In Catalog when adding a new Server, I could connect using 3 options - Use, Publish, Administer.  I could add an "admin" connection to the Server in Catalog, and perform some admin functions through that connection by right clicking and going to Server Properties.
I've tried replicating this with my new setup in Pro on a Federated Server and Portal and no matter what server address, port, and/or login I use, Pro just connects as a user (even if I use an admin account from Portal) and there are no admin or management functions tied to that connection. Am I missing something or is that how Esri unfortunately designed it? I've tried the Add ArcGIS Server connection in Pro and as soon as I type in the address of my server, it grays out the Authentication box.
How do I manage my Server in Pro? Or can't I anymore? Does Pro not give us those 3 options anymore? I'm assuming no because those roles are now tied to Portal users and roles? Could this be any more confusing?
Update: I was able to create an Admin connection in Catalog 10.6.1 using the server admin address and the Portal admin account. So that works in Catalog. Can we no longer do that in Pro?
Tags (1)
sl_dsny
Hi all.
I feel like there still hasn't been a solution provided to the administration of the services on ArcGIS Pro. The replies have been useful for sharing services (publishing and overwriting services).
I get that publishing/sharing is its own separate entity now in Pro but what if a GIS admin wants to start/stop/restart/delete services in ArcGIS Pro just like how it is in ArcCatalog? That's what the original poster was asking about.
Yes I can go to the web server manager or go back to ArcCatalog but that sounds like the opposite of integration. Am I missing a step here that allows the server connection to be Admin instead of User in Pro?
se2539
I believe you are supposed to perform those start/stop/restart/delete service admin tasks in manager only, that is, only if you have a federated setup.  At least that's what I've discovered from researching and testing with trail and error.  I mean don't get me wrong, I was a bit stumped why it seems like functionality has been taken away in some ways, but I don't see any other alternatives.
rubiales
Having the same problem and jsut came across this thread
I take there's no way to set an admin connection in Pro? If so then it'd still be appreaciated if Esri could acknowledge and advise whether that's the intended functionality on Pro
MaximeDemers
It seems like a big step back to me too. Is there at least an "idea" that was created to bring those functionnalities back?
