ArcGIS Enterprise Dynamic Filtering Options for Version 11.4
745
05-06-2025 09:46 AM
JonJones1
Problem Summary
  • Need to filter GIS data based on ArcGIS Enterprise user group memberships
  • Single database credential (dataowner) prevents PostgreSQL Row-Level Security
  • Must avoid multiple feature layer views for maintenance reasons
  • Direct PostgreSQL access needs to be preserved for ETL processes
Current Authentication Limitation
The system currently uses a single database credential (dataowner) for all connections between ArcGIS Enterprise and PostgreSQL. This prevents using standard PostgreSQL security features since all queries appear to come from the same database user regardless of who is logged into Portal.
Changing this to use individual credentials would require IT to implement several complex configurations outside of the Enterprise and PostgreSQL servers:
  1. Authentication Infrastructure:
    • Configure Kerberos or LDAP service for single sign-on
    • Set up trust relationships between domain controllers and database servers
    • Create security policies for credential delegation
  2. Network Configuration:
    • Modify firewall rules to allow authentication traffic
    • Potentially set up dedicated authentication gateways
    • Configure DNS for proper name resolution across systems
  3. User Management:
    • Create and maintain PostgreSQL database users that match ArcGIS Portal users
    • Develop automation for user provisioning/deprovisioning
    • Set up group mappings between directory services and database roles
  4. SDE Connection Changes:
    • Reconfigure connection files to use OS Authentication
    • Update all services to use the new connection method
    • Modify existing ETL processes to work with the new authentication model
Unfortunately, these authentication changes aren't feasible at this time due to IT department constraints, security policies, and potential impacts on existing systems. This is why we need an alternative approach that works with the current single database credential model.
Option 1: Server Object Interceptor (SOI)
Overview
An SOI is a custom component that runs inside the ArcGIS Server process and intercepts REST requests before they reach the feature service.
Implementation
  1. Develop custom SOI using ArcGIS Enterprise SDK (.NET/Java)
  2. SOI reads user identity from ArcGIS token
  3. Queries Portal API for user group memberships
  4. Dynamically modifies SQL queries with appropriate WHERE clauses
  5. Caches group memberships to reduce API calls
Group-to-Filter Mapping
  • Store mapping rules in PostgreSQL table, Portal item, or config file
  • Example structure: {portal_group: "SQL_predicate"}
  • Rules can be updated without recompiling the SOI
Questions for ESRI Professionals
  • Is it possible to access the Portal user's identity and group memberships from within an SOI?
  • Does the SOI have access to modify the underlying SQL before it reaches PostgreSQL?
  • What's the typical performance overhead of an SOI for this kind of filtering?
  • Will the SOI need to be recompiled with every ArcGIS Enterprise upgrade?
  • Is there a supported ArcGIS pattern for this kind of dynamic filtering that doesn't require custom code?
Option 2: Middleware/Proxy Approach
Overview
A standalone service that intercepts ArcGIS REST API requests, adds filtering, and forwards to the actual ArcGIS Server.
Implementation
  1. Develop proxy application using Node.js/Python/etc.
  2. Configure network to route client requests through proxy
  3. Proxy validates ArcGIS token and extracts user identity
  4. Calls Portal API to get user's group memberships
  5. Injects WHERE clauses into requests before forwarding to ArcGIS Server
  6. Implements caching to minimize latency
Deployment Model
  • Deploy on standard web servers
  • Scale horizontally for high availability
  • Configure with reverse proxy for SSL termination
  • Has anyone successfully implemented a middleware proxy for ArcGIS Enterprise filtering in production?
  • What's the best way to handle ArcGIS token validation in a proxy service?
  • Are there any potential issues with intercepting and modifying feature service requests?
  • Is a middleware approach officially supported or recommended by ESRI?
  • Do any ESRI-provided tools exist that could eliminate the need for custom development?
Other Options to Consider
If preserving direct PostgreSQL access becomes less critical, moving data to the ArcGIS Datastore could be an option. This would use ArcGIS's built-in security model but would require:
  • Setting up sync processes between PostgreSQL and the Datastore
  • Potentially modifying existing ETL workflows
  • Creating a strategy for keeping both data sources in sync
This approach would use more built-in ArcGIS functionality but introduce data synchronization challenges.
What solution has proven most reliable in enterprise environments with similar requirements?
