Selected features are identified improperly from a service,
3337
11-26-2014 11:10 AM
JamalNUMAN
Legendary Contributor
We couldn’t figure out why a service fail to provide correct identification for the selected feature. However, the scenarios below may highlight the issue:
  1. In the “UrbanMasterPlans_WithJoin.mxd” file, the attribute table of the “UrbanMasterPlans_PNA_Approved” layer is joined with the “Regulations” table, then the ArcGIS Server fails to identify all the selected features.
  1. In the “UrbanMasterPlans_WithoutJoin.mxd” file, the attribute table of the “UrbanMasterPlans_PNA_Approved” layer is joined with the “Regulations” table, then the ArcGIS Server is able to identify all the selected features.
Data:
http://www.mediafire.com/download/6j8a0ob26b57ou8/PublishingIssue.zip
What might be the issue here? Why the “join” affect the “identify” applied in a service?
Thank you
Best
Jamal
Jamal Numan
JamalNUMAN
  • The join is implemented
  • The identify works fine at the level of the ArcGIS Desktop 10.3
  • The identify works also properly at the level of ArcGIS Server 10.3
(The community name is Dier Estya)
Jamal Numan
JamalNUMAN
Jamal Numan
