SDE (Oracle) error when importing in ArcGIS Server
4242
11
06-05-2024 03:20 AM
LittleTurtle
I have this error when trying to publish my SDE to ArcGIS Server :
Underlying DBMS error[ORA-12154: TNS:could not resolve the connect identifier specifiedNo extended error.]
I have tried different things :
- SDE with EZconnect: works in ArcCatalog and AGS
- SDE with connection like sde:oracle11g:xyz: works in ArcCatalog and AGS
- SDE with connection like sde:oracle19c:xyz: works in ArcCatalog but fails in AGS
The instantclient installed on AGS is 19.23
The db is 19.3.0.0.0
I've updated the init_user_param.sh: export LD_LIBRARY_PATH=/usr/lib/oracle/19.23/client64/lib:$LD_LIBRARY_PATH
I would be fine if I could use SDE with 11g but with an old mxd I can't publish it, it always asks me to publish oracle19c SDE
Does anyone can help me?
LittleTurtle
Ok I'm sorry I've been able to make it work, I thought I had changed the datasource but I don't think it worked, I've done it again in ArcCatalog (right click on the mxd > Change datasource after renaming my SDE file > Choose SDE with sde:oracle11g:xyz) and saved it in another mxd
It seems to publish well (referenced data)
I still can't publish sde:oracle19c:xyz and I don't really know why but that's not blocking anymore, tell me if you have any idea though
Thank you for your help 🙂
MattFancher1
It sounds like the issue is with the 64x version of the 19c client on your AGS machine. I'd recommend working with your DBA to verify EZCONNECT is enabled and/or TNS is properly configured for that specific client. Sounds like you have a number of Oracle clients on your AGS machine and that can definitely get confusing. Good luck! 🙂
