Script for ArcGIS Server to add users and role
3554
12-08-2014 01:31 PM
GeoffreyWest
What is a proper script for this?  I have followed the resources page, but receive an EOF error when executing the code from ArcMap.
Python 2.7.5 (default, May 15 2013, 22:43:36) [MSC v.1500 32 bit (Intel)] on win32
Type "copyright", "credits" or "license()" for more information.
>>> # This script creates a bank of users and roles given a comma-separated text file
#  They should be listed in the following format and saved in a file with a .txt extension:
#  User,Role,RoleType,Password,EMail,FullName,Description
#  John,Admins,ADMINISTER,changeme,[email protected],John Doe,Server admin
#  Jane,Publishers,PUBLISH,changeme,[email protected],Jane Doe,Server publisher
#  Etc.
import json, urllib,httplib
# For system tools
import sys
# For reading passwords without echoing
import getpass
def main(argv=None):
    # Ask for admin/publisher user name and password
    username = raw_input("arcgis: ")
    password = getpass.getpass("mypassword: ")
    # Ask for server name & port
    serverName = raw_input("myserver: ")
    serverPort = 6080
    # Input File with the Role and user information
    inFile = raw_input("C:\testing\agsUsersRoles.txt:")
    # InFile = r"C:\testing\agsUsersRoles.txt"
    opnFile = open(inFile,'r')
    # Dictionaries to store user and role information
    roles = {}
    users = {}
    addUserRole = {}
    # Read the next line
    ln = opnFile.readline()
    # Counter to get through the column header of the input file
    num = 0
    while ln:
        if num == 0:
            pass # File header
        else:
            # Split the current line into list
            lnSplt = ln.split(",")
            # Build the Dictionary to add the roles
            roles[lnSplt[1]] = {lnSplt[2]:lnSplt[len(lnSplt) -1].rstrip()}
            # Add the user information to a dictionary
            users["user" + str(num)] = {"username":lnSplt[0],"password":lnSplt[3],"fullname":lnSplt[5],"email":lnSplt[4],"description":lnSplt[-1].rstrip()}
            # Store the user and role type in a dictionary
            if addUserRole.has_key(lnSplt[1]):
                addUserRole[lnSplt[1]] =  addUserRole[lnSplt[1]] + "," + lnSplt[0]
            else:
                addUserRole[lnSplt[1]] = lnSplt[0]
        # Prepare to move to the next line
        num +=1
    # Get a token and connect
    token = getToken(username, password,serverName,serverPort)
    if token == "":
            sys.exit(1)
    # Call helper functions to add users and roles
    addRoles(roles, token,serverName,serverPort)
    addUsers(users,token,serverName,serverPort)
    addUserToRoles(addUserRole,token,serverName,serverPort)
def addRoles(roleDict, token, serverName, serverPort):
    for item in roleDict.keys():
        # Build the dictionary with the role name and description
        roleToAdd = {"rolename":item}
        # Load the response
        jsRole = json.dumps(roleToAdd)
        # URL for adding a role
        addroleURL = "/arcgis/admin/security/roles/add"
        params = urllib.urlencode({'token':token,'f':'json','Role':jsRole})
        headers = {"Content-type": "application/x-www-form-urlencoded", "Accept": "text/plain"}
        # Build the connection to add the roles to the server
        httpRoleConn = httplib.HTTPConnection(serverName, serverPort)
        httpRoleConn.request("POST",addroleURL,params,headers)
        response = httpRoleConn.getresponse()
        if (response.status != 200):
            httpRoleConn.close()
            print "Could not add role."
            return
        else:
            data = response.read()
            # Check that data returned is not an error object
            if not assertJsonSuccess(data):
                print "Error when adding role. " + str(data)
                return
            else:
                print "Added role successfully"
        # Assign a privilege to the recently added role
        assignAdminUrl = "/arcgis/admin/security/roles/assignPrivilege"
        params = urllib.urlencode({'token':token,'f':'json',"rolename":item, "privilege":roleDict[item].keys()[0]})
        # Build the connection to assign the privilege
        httpRoleAdminConn = httplib.HTTPConnection(serverName, serverPort)
        httpRoleAdminConn.request("POST",assignAdminUrl,params,headers)
        response = httpRoleAdminConn.getresponse()
            httpRoleAdminConn.close()
            print "Could not assign privilege to role."
            return
        else:
                print "Error when assigning privileges to role. " + str(data)
                return
            else:
                print "Assigned privileges to role successfully"
def addUsers(userDict,token, serverName, serverPort):
    for userAdd in userDict:
        jsUser = json.dumps(userDict[userAdd])
        # URL for adding a user
        addUserURL = "/arcgis/admin/security/users/add"
        params = urllib.urlencode({'token':token,'f':'json','user':jsUser})
        # Build the connection to add the users
        httpRoleConn.request("POST",addUserURL,params,headers)
def addUserToRoles(userRoleDict,token, serverName, serverPort):
    for userRole in userRoleDict.keys():
        # Using the current role build the URL to assign the right users to the role
        addUserURL = "/arcgis/admin/security/roles/addUsersToRole"
        params = urllib.urlencode({'token':token,'f':'json',"rolename":userRole,"users":userRoleDict[userRole]})
            print "Could not add user to role."
            return
        else:
                print "Error when adding user to role. " + str(data)
                return
            else:
                print "Added user to role successfully"
def getToken(username, password, serverName, serverPort):
    # Token URL is typically http://server[:port]/arcgis/admin/generateToken
    tokenURL = "/arcgis/admin/generateToken"
    params = urllib.urlencode({'username': username, 'password': password,'client': 'requestip', 'f': 'json'})
    # Connect to URL and post parameters
    httpConn = httplib.HTTPConnection(serverName, serverPort)
    httpConn.request("POST", tokenURL, params, headers)
    # Read response
    response = httpConn.getresponse()
        httpConn.close()
        print "Error while fetching tokens from admin URL. Please check the URL and try again."
        return
    else:
        httpConn.close()
            return
        # Extract the token from it
        token = json.loads(data)
        return token['token']
# A function that checks that the input JSON object
#  is not an error object.
def assertJsonSuccess(data):
    obj = json.loads(data)
    if 'status' in obj and obj['status'] == "error":
        print "Error: JSON object returns an error. " + str(obj)
        return False
    else:
        return True
# Script start
if __name__ == "__main__":
    sys.exit(main(sys.argv[1:]))
DavidColey
MVP Frequent Contributor
Hi Geoffrey-
I ran the exact same script except I executed directly from the python idle and it works just fine.  If you do run the script directly from the python idle, note that it wants to run in the 32-bit version:
  1. Python 2.7.5 (default, May 15 2013, 22:43:36) [MSC v.1500 32 bit (Intel)] on win32
not the 64-bit version.  My file looks like:
User,Role,RoleType,Password,Email,FullName,Description
scae,AddressEditors,ACCESS,password,[email protected],scae,AddressEditor
Top row is read in as the header, all subsequent rows contain your values.  If the ROLE already exists, the script should ignore and populate the rest into your store.  Hope this helps
khairulamri
Hi Geoffrey,
I ran the script successfully.
in enter server name, put your gis server url without http like this : gis.myserver.com. I got error when I put http
also put your txt file without quotes. pfa for the sample scripts
