Schematics generating empty diagram ArcGIS 9.3
1274
12-21-2016 04:00 AM
RohitShome
Am trying to generate the schematic diagram based on trace. I've created a schematics data set using the steps mentioned. However when I generate the schematics diagram, it generates only an empty diagram. Have I missed something??
Tags (1)
Vara_PrasadM_S
Hi Rohit Shome‌,
Could you please let me know if you could solve this issue. I am also running into a similar issue. I am able to generate a schematic diagram through addin in ArcMap. but with the same code, if I run it as a console application outside ArcMap, it is generating the empty diagram.
Any inputs would be very helpful.
Thanks a lot in advance!
With Regards,
Vara Prasad
