Republish ArcGIS Online tiles as a reprojected map service
2682
5
05-02-2013 08:14 AM
ab1
I'd like to use ArcGIS Online basemaps but not is the Web Mercator projection. Because of that I want to know if it's possible to reproject and republish them in a Map Service.
=> Is it possible to recover ArcGIS Online tiles of a zone, then reproject and republish them in a Map Service?
DerekLaw
Esri Esteemed Contributor
Hi there,
No, you cannot re-publish ArcGIS Online basemaps as your own web services.
Hope this helps,
ab1
Ok thanks.
Is it technically or legally impossible?
DerekLaw
Hi there,
Both.
Hope this helps,
ab1
Could you elaborate on how it is technically impossible ?
I managed to republish a dynamic map service from an ArcGIS Online service:
- I created an MXD
- I set the projection of the group layer to the projection I want
- I added an ArcGIS Online map service to the group layer
- Then I published the MXD as a map service and it worked just fine (as dynamic map service)
But then when I tryed to create a cache from that service, it seems that the tiles were not "georeferenced(?)" correctly :
The coordinate system of the tiles seems to have been changed to the one of the MXD, but the coordinates themselves weren't reprojected.
=> When I try to go to the location (x,y), I don't get the correct location.
PS: I know you said this is illegal, but I'm trying to understand how map services work in this case. I'm not going to use this method.
DerekLaw
Hi there,
Sorry, I cannot comment further on this topic.
