Repeated Data Store Warnings in Logs
781
05-09-2025 11:57 AM
phess_luckstone
We've been having some weird issues lately and every night around midnight we are seeing these errors on our base install of enterprise (11.1) Has anyone else seen this or knows what causes it?
LevelTimeMessageSourceCodeTime ElapseUserNameProcessThreadMethodRequest ID
WARNINGMay 9, 2025, 12:01:13 AMFailed to create index on '{0}'. ERROR: syntax error at or near "," Position: 52Data Store110586  33561
WARNINGMay 8, 2025, 12:01:13 AMFailed to create index on '{0}'. ERROR: syntax error at or near "," Position: 52Data Store110586  33561
WARNINGMay 7, 2025, 12:01:12 AMFailed to create index on '{0}'. ERROR: syntax error at or near "," Position: 52Data Store110586  33561
WARNINGMay 6, 2025, 12:01:12 AMFailed to create index on '{0}'. ERROR: syntax error at or near "," Position: 52Data Store110586  33561
WARNINGMay 5, 2025, 12:01:12 AMFailed to create index on '{0}'. ERROR: syntax error at or near "," Position: 52Data Store110586  33561
WARNINGMay 4, 2025, 12:01:11 AMFailed to create index on '{0}'. ERROR: syntax error at or near "," Position: 52Data Store110586  33561
WARNINGMay 3, 2025, 12:01:10 AMFailed to create index on '{0}'. ERROR: syntax error at or near "," Position: 52Data Store110586  33561
WARNINGMay 2, 2025, 12:01:10 AMFailed to create index on '{0}'. ERROR: syntax error at or near "," Position: 52Data Store110586  33561
WARNINGMay 1, 2025, 12:01:09 AMFailed to create index on '{0}'. ERROR: syntax error at or near "," Position: 52Data Store110586  33561
TimWestern
MVP Regular Contributor
Just spit balling here. Here are some things I would check.
1. On the server where you are running this, right click the drive that it runs on and see how much Disk space is left.
2. If its not on a C Drive, but on a mapped one, do the same there.
3. Do the same for any database sources that your system has configured, any of them having insufficient space could cause such an error.
4. Do you have any nightly backups that might be running around this time? This looks oddly similar to an issue I saw when one of our unrelated services blew up its log folder and took up a lot of hard drive space making backup not possible.  (Its also similar to some issues I saw when a user tried to route to a particular location while the site was going through a backup/or was unresponsive during it.)
5. I'd be interested what you find in your webserver lo0gs for traffic around that time at night? maybe some request occurring around the same time is responsible for causing it?
(Note not saying this is all that it could be, b ut something here, makes me think 'drive space issue')
