ArcGIS Enterprise 11.3 net::ERR_CONNECTION_RESET errors while using javascript sdk
1426
04-15-2025 06:37 AM
omar-marji
Hello All,
I am consistently seeing net::ERR_CONNECTION_RESET logs in the chrome console with a web application written using the JS SDK.
The web map being viewed contains layers form a utility network, and as soon as a user zooms in and out 4-5 times, the layers are no longer shown on the map and the chrome console is full of net::ERR_CONNECTION_RESET errors.
All patches are installed on the server (Windows Server 2022).
I found this post (https://community.esri.com/t5/arcgis-enterprise-questions/arcgis-server-web-adaptor-possible-problem... which points to a registered bug here  (https://support.esri.com/en-us/bug/arcgis-web-adaptor-may-stop-responding-to-requests-when-bug-00016... and was wondering if anyone else ran into this issue and was able to find a work around.
TimWestern
MVP Regular Contributor
Those links seem to be broken.
omar-marji
Thanks for the reply, there was an extra ) at the end. I've updated the post
