Rename an ArcGIS Enterprise Machine
1486
03-08-2024 09:15 AM
NathanHeickLACSD
I attempted to use webgisdr to migrate to a new machine with a different hostname and alias.  I was mostly successful in doing so.  The internal URLs were setup before the import.  I reinstalled the web adaptors after the import with the alias.  However, I still notice the old URL in various places like the link to generate a token from the Server Administrator Directory or in the service properties in the Server Administrator Directory.
Is the expectation of webgisdr that the target machine always takes over the hostname or alias of the source machine?  Is there a way to update the URLs everywhere in an ArcGIS Enterprise installation?
ReeseFacendini
Esri Alum
When using Enterprise with an alias, webgisdr keeps that same alias information and there's not a way to change it by restoring to a new system.
Esri Professional Services can help change the alias of an Enterprise system, but it's not a supported workflow outside of that group (i.e., Support Services won't be able to help).
ReeseFacendini
Esri Alum
NathanHeickLACSD
Thank you Reese.  That's the feeling I got.  Doable if you really understand the internals of the software, but risky if you don't.
MichaelVolz
Esteemed Contributor
Have you ever taken advantage of hosts file at C:\Windows\System32\drivers\etc?
