Hi.
I have published an image service where I used polygon to clip a raster image, so the area of the image where there is no content will be clipped. However, when I add the image service to a map in AGOL, the image is not clipped anymore. On the other hand, if I view the service in ArcGIS JavaScript viewer from REST API, or if I add it to ArcMap the image is shown correctly.
I think it used to work some time ago, but not anymore. Any idea why is this happening. The image is cached.
Thank you.
Martin
Hi Martin,
What type of raster are you using for your Image Service (i.e. Mosaic Dataset, JPG, TIFF)? Also, are you applying the clip using the Clip Function?
