Python toolbox building a PDF report with reportlab crashes ArcSOC.exe
3284
09-18-2016 03:16 PM
FraserHand
Hi There,
I have a Python toolbox published to ArcGIS for Server 10.3.1 that uses the reportlab python module to create  PDF. What I am seeing is that the after we have built the PDF scaffold once we try to build it the ArcSOC.exe crashes. This is on the reportlab pdf document build() function. If we try to execute the tool again it runs fine. This is a multiple machine site but both machines are the same and it seems to crash on both nodes. The script works fine every time from the Python interpreter.
Is there any additional logging we can get to, which may explain why the ArcSOC crashes? Does ArcGIS Server set up the Python environment in a certain way as I see errors (especially around encoding) occur in the Esri environment that doesn't happen in a pure Python environment?
Has anyone seen similar issues using reporlab? Has anyone seen ArcSOCs crash during Python toolbox execution?
Many thanks
Fraser
MarkEastwood
@Fraser Hand did you ever resolve your issue? I seem to be having a similar problem.
FraserHand1
I think it was an encoding issue around some characters with accents from memory.
Fraser
