Publishing Geoprocessing Service that use Feature Service URLs
637
03-28-2022 11:11 AM
ZacharyHart
Honored Contributor
I've developed a script tool which I'm looking to publish as a GP service. The script leverages several feature service URLs from our Enterprise system hard-coded inputs for the script; using direct DB connections to the under lying database isn't a viable option.
Obviously, you cannot/do not register server URLs with your Data Store, but since the validation process cannot find these resources in the Data Store, it warns that the data source is not registered and will therefore be copied.
I thought that maybe I could simply parameterize these URLs in the Script Tool but I'm not sure that you can make these hidden or locked.
Is there anyway to go about publishing this without using a direct DB connection?
sxw_eaglegis
Hi there - Could split up the URL in your script to get around that, like this:
site = "https://server/arcgis/rest/services"
service = "/Hosted/layer/FeatureServer/0"
serviceURL = site+service
ZacharyHart
Honored Contributor
Unfortunately, this doesn't seem to trick the validation process:
ZacharyHart
Honored Contributor
Is there anyone from Esri willing to answer this?
