Publishing a layer creates lock and my python script cannot replace the feature class
5404
11
11-04-2021 11:49 AM
al_Dhakal
Hello, I get a fresh csv every morning that I geocode and publish as a feature layer to be consumed in a dashboard. Now when I use python script to automate the workflow every morning, I see a lock from my ArcGIS Server service account. This lock (probably) doesn't let the python to overwrite the feature and a result, the new feature class that gets created appears in UPPER CASE and as a stand alone layer (not inside feature dataset). From second time around, the script just fails because either it couldn't overwrite the feature class or because it thinks there is already a feature class with that name inside the enterprise geodatabase.
So, basically how can I overwrite a feature class that is published and hence has a lock from service account using python?
Tags (3)
CamMuller
Hi @al_Dhakal, I have faced a similar problem relating to the loading of data with locks occurring from the AGS.
My method around this, taking into account the client-specific workflow, was to stop the required service on AGS using python which releases the lock, load the data, and then restart the service.
Hope that helps.
al_Dhakal
Hi all, thank you for all the suggestions. The easier solution that worked for my (as of now) is to use the database view and publish the view layer instead. This way, there is a lock established on the view feature class only and I can use python scripts to overwrite the original feature class. More on the database view here - https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/create-database-view.htm
