Publish image with predefine symbology
353
08-12-2024 07:10 AM
mody_buchbinder
We would like to publish a raster that will have predefine symbology.
For example DTM in none gray symbol (starch or classes).
Here: https://enterprise.arcgis.com/en/server/latest/publish-services/windows/key-concepts-for-image-servi... it say that you can publish a layer file. I could not find a way to publish a lyrx file.
Then you can create a function that is created from the renderer. The problem with that that it looks fine but you loose the original value (height in dtm) and you get RGB only.
We can define it on the client but each client will have to do it by himself.
Is there any simple way to do it?
