Problems with publishing a service multiple layers
982
06-20-2013 03:35 AM
DenizGueclue
Hi guys!
I've the following setup:
-ArcGIS Server 10.1 and ArcGIS Desktop 10.1 both installed on the same machine (Windows Server 2008).
- A network-share which i use as my central storage
My goal:
- To publish a service by using ArcMap.
What I've done:
- I gave to the ArcGISServer-User all permissions on the network-share
- Registered the folder/share
- Added 2 Layers (from *.gdb) to ArcMap
- Tried to share as service but got the following error: "Packaging succeded but publishing failed"
- Tried another way: Created an .sd file and uploaded the file to the Server. This worked but only one Label is published in the service. When I look into the logfile of the service I can see the following error/warning: Code 10801 - The Layer "Layer2" is invalid.
If I try to publish only Layer2 by using a .sd file it works fine. But i need both Layers in one Service.
Can anyone help me?
Thank you,
Dennis
MichaelVolz
Esteemed Contributor
Does the following KB article apply to you:
http://support.esri.com/es/knowledgebase/techarticles/detail/40391
DenizGueclue
Hi!
I don't think so...I'm not using any Samba. And the problem occurs only if I try to publish 2 Layers in 1 Service.
Any other ideas?
