Problem with Publishing 3D Trees from Pro to Enterprise
943
08-15-2024 11:58 AM
MohamadYadegari
I am using ArcGIS Pro 3.3 to publish 3D tree dataset from SDE to Enterprise.
In previous pro version I used low poly tree symbols, and then changed the symbology to Realistic symbols in enterprise and everything was fine.
After updating Pro to 3.3 we are not able to use the low poly anymore as I am getting error in enterprise.
Instead I used simple ArcGIS point 3Ds but once I check the scene viewer, I can not find the points there, but based on legend and layer I am pretty sure they are there.
Anyone has any idea or solution?
thanks in advance
ArthurCrawford01
You could add z to the points to make they 3D using the elevation and then use the height field of the trees to make them 3D.   You might be able to set the height to ground (elevation layer) without adding z.
