Portal printing tools
1602
02-06-2025 06:39 AM
ElieRizk
the printing tools are not shown in the utilities folder in the portal content.
kindly advise how to find or re-add it to the portal content. noting that it is existing in the services directory.
TimoT
Hi @ElieRizk,
I've had to do this before.
Go to Portal > Content > New item > URL, then input the REST URL of your printing tools geoprocessing service e.g. https://server.domain.com/server/rest/services/Utilities/PrintingTools/GPServer
You will additionally need to edit the PrintingTools service json so that it references the correct Portal item ID, otherwise you will encounter some permissions related quirks for non-administrator users. To do this:
  1. Login to Server Admin Directory (e.g. https://server.domain.com/server/admin) for the ArcGIS Server that hosts your printingtools
  2. Navigate to services > Utilities > PrintingTools.GPServer > edit
  3. Find the itemID parameter in the JSON code and edit with your newly created PrintingTools item ID.
  4. Save your edits
RyanUthoff
MVP Regular Contributor
You might try this workflow here: https://support.esri.com/en-us/knowledge-base/how-to-add-the-printingtools-service-from-the-arcgis-r...
If the printing service URL is already set in your Portal organization settings, you might be able to take the REST URL of the printing service and add it as an item in Portal. I haven't tried that workflow before, but it's something I'd try.
TimoT
Hi @ElieRizk,
  4. Save your edits
