Portal for ArcGIS upgrade from 10.6.1 to 10.7 failed
4688
21
04-25-2019 02:57 AM
NicolasGIS
I faced an error while upgrading from Portal for ArcGIS 10.6.1 to Portal for ArcGIS 10.7.
The following error occurred during the upgrade:
Digging into the log in C:\arcgisportal\logs\FQDN\portal, I noticed the following error:
<Msg time="2019-04-25T10:19:54,94" type="INFO" code="209081" source="Portal Admin" process="3436" thread="1" methodName="" machine="FQDN" user="" elapsed="" requestID="">Postgres DB upgrade response
could not open version file: C:\arcgisportal\db/PG_VERSION
Failure, exiting
.</Msg>
As you can noticed, there is a mix of backslash and forwardslash as the file does exist in C:\arcgisportal\db\PG_VERSION but of course C:\arcgisportal\db/PG_VERSION is not a correct path.
Operating System details: Windows Server 2016 Standard
Any idea ?
Thanks
JonathanQuinn
Esri Notable Contributor
Set a path filter for C:\arcgisportal\db so any file based traffic to that directory is logged. If ProcMon records an error indicating that the path doesn't exist, but you can confirm manually that it does, then that could be the problem.
Windows itself shouldn't have a problem with slashes, it can sort out that C:/test is actually C:\test, for example. Linux is different, of course.
If the code has a problem with that, then that's another story.
NicolasGIS
OK Thanks. I will give a try and let know you the results
NicolasGIS
Do you mean region by locals ?
ThomasEdghill
Esri Community Moderator
Hello Nicolas GIS‌! It looks like you would benefit from taking this issue over to Esri Technical Support, so that we can have a deeper investigation and troubleshooting with the help of our analysts there.
If you need some assistance with getting a case created, let me know and I'll be happy to assist.
AndrewBartshire
I just had the same issue but going from 10.6 to 10.7. After hours with tech support it looks like the issue may have been related to "built-in" Portal PostgreSQL DB error that may have happened during initial installation. We run a "external" PostgreSQL 9.6 DB as as a managed EGDB but apparently during the install something went wrong and the "external" DB was acting in place of the "built-in" which didn't present issues until upgrade time. The solution so far has been to completely uninstall Portal rather than upgrade and copy back all settings, content, etc.
JonathanQuinn
There should be no conflict with running your own instance of PG on the same machine as Portal. They run on different ports, have different data directories, etc. Was the analyst able to reproduce the problem and log a bug?
AndrewBartshire
The issue wasn't that they couldn't both run, but that there was an issue somewhere along the way so the internal Portal DB wasn't operating. When Portal service is enabled the corresponding PG services that spin up were from the external PG, not from internal. This was identified through task manager displaying the datastore PG services displaying normally but none from portal.
LorenzMeyer1
Hi
I ran into this issue yesterday evening again. I have no idea why. I opened once an Esri case "Case #02409929" in September this year (Esri Germany). Afterwards I could not reproduce the error again until now.
We plan to migrate our production environment in January 2020 and yesterday I did a dry run to migrate portal to new machines and to upgrade from 10.6.1 to 10.7.1.
The error message at the top points me as well to the logs in "C:\arcgisportal\logs" but we did not even install to c:\arcgisportal, our directory is d:\arcgisportal\logs and in there I could not find any logs from the "upgrade" failure.
Have you more information what the upgrade failure could trigger or how I could work around?
Thanks
LorenzMeyer1
I've opened a new Esri case "Esri Case #02454529 - ArcGIS Enterprise - Portal Upgrade 10.6.1 to 10.7.1" with all the logs found so far.
BarbaraS
Lorenz Meyer‌, how did you resolve the issue in the end? I tried to change my regional settings back, as described here by Antigoni but now I can't open the createadmin.html site anymore after I did a restart.
